JD A carb. I.D.
John Hicks
08-08-2003 20:28:21
I have a 1937 "A" with a DLTX 53 carb on it. A listing in Two-Cylinder magazine shows this tractor as having a DLTX 18 carb. The ser. No. of the tractor is 444801. Does anyone know the difference between these carbs? Thanks Much,
John
Duane Larson
08-08-2003 21:00:35
 Re: JD A carb. I.D. in reply to John Hicks, 08-08-2003 20:28:21
John,
There are several differences between the 18 and 53 - externally, the 18 was a hand-choke unit while the 53 allowed attachment of a choke control at the dash. Internally, they used different nozzles, economizer plugs, and had some differences in internal passage diameters. They will physically interchange (except for the choke linkage) - it would be easier to use a 53 on an unstyled A than a 18 on a styled A.
Marvel Schebler (in their literature) drives home the point that each carb is designed for a particular engine, and interchange is not recommended. Will you notice a difference in your operation with the 53 than the 18 - probably not a lot - it would depend more on the condition of each carb.
