to anyone that has G or GM
36 A
01-17-2004 13:07:17
Has anyone ever run across a g with the PTO gear section broke from the case.This is the part where the gears turn and go out the back,under the trans.Mine is junk and wondering if any body else has seen this.
JDGnut
01-17-2004 22:01:05
 Re: to anyone that has G or GM in reply to 36 A, 01-17-2004 13:07:17
When my dad was growing up.. they had a G with .125 M&W's in it.. While pulling a Silage chopper they broke that piece of in the housing... and then sold the tractor... I guess it wasn't the only one... JDGnut
g pop
01-17-2004 18:45:23
we got a gm that has the cast iron yoke busted off ,there are two things you can do find a good welder and put the piece back or find a good housing and build the tractor back,
JohnDeere_John
01-17-2004 13:11:46
Good chance it was proably hooked to a bush hog with no clutch or shear pin to protect it in case the mower hit a rock or stump. A break in the pto system caused by this type of damage can be any model or make tractor. Jon
