3020 loader
jeff
08-12-2003 07:38:10
i am adding a loader to my 3020 and i bought the special filter cover with the port for the return oil.
i tried to install it yesterday and found that the original cover bolt is way too short.
i measured the new housing against the original and it is a full 1.25 thicker so no threads can catch.
has anyone had the same problem? i would think that they would supply a longer bolt with the kit. the kit had the large gasket, two o-rings for the return port? and an o-ring for the bolt.
my next concern is if by adding a longer bolt the spring behind the filter will have any pressure on it? thanks,
davidval
08-12-2003 11:05:43
 Re: 3020 loader in reply to jeff, 08-12-2003 07:38:10
no go, if you use the longer housing the filter will not seal. maybe the longer (and finer) 40 series filter can fit.
david
jeff
08-17-2003 19:09:11
 Re: Re: 3020 loader in reply to davidval, 08-12-2003 11:05:43
jd ordered me the "correct" bolt. that only took three days. by the way it was 1 inch shorter than the original one which was 1.25 inch too short so i made one from all-thread and added another spring to hold the filter tight.
also , it seems jd is hitting me with $8 freight charges for every stinking nut and bolt they have to order because they don't have any inventory.
