4020 quit moving
Joe
08-18-2003 19:33:28
I have a 4020 diesel powershift(early model). I was using it and it all at once quit moving and I lost my steering and hydraulics. Do you guys think the disconnect plate broke? or should i start somewhere else when i start to work on it? I didnt hear any noises when it quit. thanks in advance for any replys. Also the pto does not work.
G-MAN
08-20-2003 13:53:19
 Re: 4020 quit moving in reply to Joe, 08-18-2003 19:33:28
It could also be a tranny pump issue. The trans pump charges the main hydraulic pump, in addition to supplying system pressure to operate the trans. It could also be as simple as material from a bad brake pad (in the final drive) plugging up the sump screen, that the oil passes through before going to the tranny pump.
david valtzer
08-19-2003 03:37:40
either the disconnect disk or the clutch pack input shaft is broken.
david
