2510 hyd. coupler
joe
08-19-2003 05:25:04
2510 powershift-47 loader,having to replace coupler between crankshaft and front pump about 100 to150 hours.main use of tractor is to move 6/5 bales to hay storage.loader hooked to rear remote.any ideas? thank you.
McC
08-20-2003 09:08:56
 Re: 2510 hyd. coupler in reply to joe, 08-19-2003 05:25:04
Check the frame rail bolts and make sure they are not loose.
joe
08-20-2003 05:28:02
sorry mind on next project when profreading. coupler only strips at pump end ,have replaced all bolts and stud,bushings at c/shaft.all parts jd.does not look out of round or out of line.pump splines feel ok, (but) dont know what it should look ,feel,or measure out to be.only noise it ever makes is squeel as coupler starts to strip
thank you joe
DON
08-20-2003 14:22:59
 Re: Re: 2510 hyd. coupler in reply to joe, 08-20-2003 05:28:02
Hey Joe, if the cast coupler is stripping out then the splines are more than likely shot on the pump shaft.
DON
08-19-2003 13:37:38
YOU NEED TO CHECK THE ALUMINUM COUPLERS EACH TIME FOR WEAR AND REPLACE THE BUSHINGS AND POSSIBLY THE SPECIAL BOLTS THEY GO ON AS WELL. ALSO CHECK THE PUMP BRACKET BOLTS FOR TIGHT AS WELL AS THE CAST COUPLER SPLINES. HOPE THIS HELPS.
DON
08-19-2003 13:37:28
davidval
08-19-2003 09:34:32
either loose bolts and/or broken or missing dowells between engine and pump support.
