John Deere model 40 service
Jim Van
08-24-2003 14:54:06
Can anyone help with the correct procedure for fan belt replacement on my model 40? It looks as the entire fan assembly needs to be removed to replace the fan? That does not seem right (I hope). Can anyone provide illumination on the easiest way to replace te belt?
Wayne in Tn.
08-24-2003 16:06:55
 Re: John Deere model 40 service in reply to Jim Van, 08-24-2003 14:54:06
Jim, If you are only wanting to replace the belt, there is a big nut on the backside of the fan bracket, loosen this nut and slide the fan & pulley assembly down to loosen tension on the belt, slide it up to tighten tension, and tighten the big nut. There is a big cotter pin through the fan shaft to keep it from turning while turning the big nut. If this has not been done recently, it may be a pain. Liberal amounts of penetrating oil will help.
