M starting problem
Johan
08-27-2003 11:51:11
Tried to start the M first time since spring. No luck at all! Good compression, spark is there, good flow of gas to carb and from drain in carb bottom. Bone dry sparkplugs despite having cranked and choked on and off. Any advice would be highly appreciated. Thanks.
DiggerLarry
08-28-2003 10:15:29
 Re: M starting problem in reply to Johan, 08-27-2003 11:51:11
Sounds like the carb jet is clogged.
DL
Bus Driver
08-27-2003 16:22:32
With the tractor outside and away from any building, use a pump oiler to squirt some gasoline into the intake of the carburetor. If it will then fire a bit, the problem is a clogged jet in the carburetor. My M has adjustable high speed jet and adjusting it richer may permit the fule to flow. If so, within a few minutes of running, the mixture is likely to become too rich and readjustment will be necessary.
