1954 Model 40 - 10wt. + 90wt.; What to use now?
joe
09-10-2003 20:24:34
Hello to all, I just brought home my grandpa's old 40, he bought new and used until he passed 2 yrs. ago. Was wondering what I should use,still 10wt.in touch-o-matic and 90 everywhere else or some new type of oil? Thanks, I'm sure I'll have some more ?'s as it goes. I already have original operators manual and I got a shop manual also, but experience from others has never hurt! I am trying to make this a real sight for my Grandma(90 yrs.old) to see,got to work fast. Thanks again for any and all help!
Henry J
09-11-2003 09:41:40
 Re: 1954 Model 40 - 10wt. + 90wt.; What to use now in reply to joe, 09-10-2003 20:24:34
Joe
Food for thought. The trans oil is the same that lubes the differential. For decades now the auto/truck industry has always said that GL 5 rating lube should be used on differentials that have gears that are cut like Dubuque tractors (I think they call it hypoid). Personally, I will always use 80-140 GL 5 in my 420 trans.
Fred Mills
09-10-2003 20:33:42
Joe, I use JD hydraulic in the power trol,30 wt. in the engine and 80w-90 in the transmission. My tractor is a 1954 JD 40 standard.
bleete
09-12-2003 14:01:22
 Re: Re: 1954 Model 40 - 10wt. + 90wt.; What to use in reply to Fred Mills, 09-10-2003 20:33:42
does any one know of parts also have 1954 40U looking for axle block casting # M1611T bleete @ timber2k2@aol.com
Wayne in Tn.
09-11-2003 07:38:22
Joe, those old systems were built before the modern types of hydraulic oils, I still use the 10w non-detergent motor oil in the lifts. And if the transmission has any gear noise, I use 140w gear oil in them. Also since those engines have solid lifters, and if they have not been recently overhauled, I use 30w non-detergent oil in the engine.
joe
09-11-2003 13:40:32
 Re: Re: Re: 1954 Model 40 - 10wt. + 90wt.; What to in reply to Wayne in Tn., 09-11-2003 07:38:22
Thanks for the input guys, I really appreciate it. The old tractor is really straight and putts just like it always did. I am going to give the tin a paint job and hope Granny gets a chance to see it, then give it a good going over after that. Thanks again, Joe.
