Smoking battery
Jim M (RI)
09-14-2003 03:34:55
I recently purchased a 52"A". It started fine when I picked it up. It has set for about a month now. Yesterday I tried to start it, and when I steped on the starter, nothing happened. A few seconds later I noticed smoke coming from under the seat. It was coming from the ground (+) wire. The cable and connection was not good, so I made a trip to NAPA and replaced the wire. Tried to start again and same results, expept this time the negative terminal was smoking. The terminal looks ok, and this wire leads under the seat, etc so it would not be easy to replace. Any ideas what is going on or suggestions as to what I should check? Thanks, Jim
John T (More Info)
09-14-2003 10:51:49
 Re: Smoking battery in reply to Jim M (RI), 09-14-2003 03:34:55
Hi again Jim, I am back at my computer for a bit now (sorry, had to make a trip to town) and will add a few more things you might need to try:
If all your cable ends and cables and grounds and battery all check out per my post below and you still have problems, heres some other thigns to check.
1) Inspect the starter pedal and rod linkage to make sure its allowing the start switch to be depressed fully down. If its not fully depressign the switch, there can be a bad connection causing heat and carbon to build up.
2) Remove the start switch (disconnect battery first) and see if theres carbon and/or the copper post coming out of the starters side is burned or pitted or carboned. If the post or switch contact is burned or carboned or pitted, it can not work properly and even smoke.
3) Be sure the starters drive gear is not stuck engaged and/or bound up. You could loosen the starter mountign bolts and insure the gear is not stuck. I doubt the engine is stuck, but if so (or the starter drive is stuck), it can cause the starter to overheat and also the excess current draw in the cables might cause heat and smoke at connection points. Does the flywheel turn over okay manually????? ??
4) In my original post I first asked how well the engine cranks over, and if the answer is fine, its probably more of a cable or connection problem. If not well, check the switch and starter post and drive per the above.
Hopefully, this is enough info to find your problem, but if not e mail or poast back or call. PS Does the starter get real hot when you try and start her????? ?? Does it have that classic burned electrical smell???? You could have a brush or other starter problem, but we will save that for a later post if needed. Let us know.
Good Luck n God Bless
John T
720 guy
09-14-2003 11:21:18
 Re: Re: Smoking battery in reply to John T (More Info), 09-14-2003 10:51:49
Kind of misssed the problem there didnt you JohnT. clooney gets it then you gotta copy his and have the last word. I seen this more than once lately. You gotta start signin it Last Word John/
John T
09-14-2003 11:54:32
 Re: Re: Re: Smoking battery in reply to 720 guy, 09-14-2003 11:21:18
Good afternoon there 720 guy, Heard no word back about the smoking problem or answers to any questions, (been out mowing a bit) so cant be for sure yet whats happening. Hope for him though its something simple, those darn things can be expensive for sure grrrrr rrr. Its either about gotta be a bad connection (AlWAYS check those first, cheap n easy) or cables or grounds or battery or a bad starter or starter drive or the engine is stuck (pray its not a bad starter or stuck engine for his sake) or switch or the side out starter post though I figure, so we pretty well got him covered to troubleshoot about ALL possibilities and sorry if any were missed, but I do my best and try and help the best I can. Tractor folks are the finest people Ive met and we all try n help each other on here. However, I will save the starter info for later though (brushes, drives etc).
You had any similar problems??? What was the cause of your smoke??? Let us know what you found in any similar circumstances and hopefully we can get Jim up n running.
Take care n thanks for the input, e mail or call or post back.
God Bless
John T PS yours a gas or diesel 720??? Ive owend both and wish to heck I still had all the oens I sold years ago.
Clooney
09-14-2003 07:31:20
Jim, first thing to do is determine IF the engine is locked up. Try to turn it by hand or try pulling the tractor in high gear.
~A locked up engine [very possible after sitting a month] could cause the smoking & battery post/cable heating.
~While poor connections & bad cables can & do cause that type of battery/terminal smoke it usually also slowly cranks the engine or at least makes the starter rattle. With your starter doing NOTHING & the only place the starter circuit can complete being at the starter switch it sure sounds to me like a locked up engine [or starter]..
~If the engine spins freely then suspect a rotten battery cable between the starter & battery OR, a locked up or shorted starter... If the battery cable gets real hot while trying to crank, suspect a starter or engine lock up [hopefully the starter drive is just jammed in the flywheel teeth [try turning the engine backwards to free it].....
~Let us know what you find?.....
JDClooney@aol.com
John T
09-14-2003 07:18:11
Good Morning there Jim, That tractors old enough to smoke, but smoking not good for us I hear, so hopefully we can get you fixed.
When cranking her over, HOW WELL DOES SHE CRANK OVER THE ENGINE????? ? Is it fairly fast or real slow and draggy????? ?? Is there smoke anyplace besides under the seat??? Where at??? (cable ends, grounds??) If shes sat a while and the battery has any problems or has been discharged (maybe a slight short somewhere) it can be ran down and thats a cause of heat and smoke etc. Give her a good charge, check and tighten the battery cable ends and grounds, and see what happens. Heres a more detailed troubleshooting procedure:
1) A leadign cause of the smoke you described is loose or carboned up battery to cable connections or bad cable ends (like on the lighter cheaper stamped on end type) which can appear fine on the outside but have carbon build up underneath. Try cranking with the seat top removed and see just where the smoke is coming from ???? If at a battery terminal post, remove, clean and wire brush the battery post and cable end inside circumference, and replace and re tighten and see if she smokes after that and where????
2) That cable that goes under the seat you described snakes its way down to the starter. Its possible for them to develop bad insulation (breaks, rots, rubbing somewhere against tractor). However, if thats the case, they could short out and cause big time smoke ANYTIME, not just during cranking. An ohm meter or continuity test on that cable (removed from battery and starter) should show an open circuit high resistance (near infinity depending on type and quality of meter and other thigns) between it and frame steel. If theres any continuity or low resistance, its shorted somewhere or could have gotten against the starter rod or flywheel and rubbed off the insulation.
3) The batetry cables should be at least 0 Gauge and the heavy duty types, not lighter gauge stamped on terminal types that can smoke under the stamped end between it and the cable if carbon builds up there.
4) Any weak connections at any other places, like the cable to starter or ground cable to frame attachment or if the ground point itslef, like if to a seat or battery box is corroded or not well bonded to the tractors main frame, can cause heat build up. You may as well remove, clean and wire brush and re attach ALL OTHER cable and starter and ground connections and/or atatch the ground cable somewhere direct to the frame, independent of the seat or battery box.
5) A weak battery or a bad draggy starter can cause excess current draw and heat and smoke at a weak point in the system. Is the battery in good shape, fully charged, electrolyte level above all plates, and no gray or milky color in any cells??? You might try a good charge and/or try a known good substitute battery and see how it does and a battery shop could load test the battery to determine its condition.
First try and determine whats smoking and concentrate your efforts there. The seat or battery box may not be well gorunded in which case re atatch the grund cable DIRECT to the frame. If any cable ends are smoking, remove, clean and wire brush and re atach. Check the battery charge and condition and other cable atatchments (grounds and starter) and see how well she cranks and if any smoke and where. Its hopefully just a low battery or bad or loose or carboned up cable end problem.
You can e mail me at jmn50@msn.com or call me at (812) 824-4608 or post abck any info or questiosn and I will try and get you going SMOKE FREE.
Good Luck and God Bless
John T Nordhoff
