wheel weight bolts help?
Joe
09-15-2003 05:42:05
Have a '64 3020 with 3 weights on each rear wheel. The left side has 3 bolts sticking out the outermost weight. They are splined down to the threads and are not the 3 main bolts holding the weights on. What could these have been for? Thanks.
720Deere
09-15-2003 07:33:27
 Re: wheel weight bolts help? in reply to Joe, 09-15-2003 05:42:05
Those weights have bolts in each weight. You should find that the weights have 6 holes in them. The splined bolt is driven into the recessed holes on the back of the weight and each additional weight is bolted to the last. Most people these days add multiple sets of weights on one set of long bolts. Those special weight bolts are still available from JD and cost about $4 each.
