indydirtfarmer
09-16-2003 09:55:01
Re: What is honing a block? in reply to Jimmy, 09-16-2003 09:11:58
I'm no automotive engineer, but I'll try to give you the highlights of "honing". A piston must have a very accurate bore to operate correctly. Boring gets it very close. Honing is more or less, the finishing touch. A cylinder wall must have a certain "finish" in order to wear properly. That is what honing is all about. The stones used to hone a cylinder, give what is known as a "cross-hatch" or small grooves, in a spiral pattern. They hold oil to lubricate the piston vs. cylinder wall. They also allow the piston to have contact with less of the cylinder wall, to cause less friction. Honing will take out only a very small amount of metal, from the cylinder wall, to give just the right amount of clearance. You can hone a block, to clean it up, when re-building an engine, ONLY if the block isn't worn beyond servicable limits. If it is worn MORE, it needs to be bored to the next available piston size, and then honed to the correct wall finish. There is usually a small tolorance for piston to wall clearance, that will permit SOME honing, on a used block, with "standard pistons" Honing can be done by hand, if you have a good understanding of what you are doing, but it is one of those things best left to experienced machine shops, to get that perfect cross-hatch, and the correct piston clearance. This is what I've always been taught. Someone that has had more "formal education" in engine mechanics, will most likely be able to explain it better than I. Hope this is of some help. John
