Intake Valve interchangability on m9del B
Jerry 41 B
01-20-2004 19:33:50
Hi I have a 41 b ser# 120***
I am in the process of reassembly and hit a snag.
The intake valves when ground dont have enough margin left. So I found some used ones. Part #B 2863 R. Which is what the book calls for as replacemnt for all b's 96000 and up. But now here is my problem The valves I got as replacments are 6 3/4 in long vs 7 1/2 in long. Can I use the shorter valves if so what kind of modification do I need to do. Thanks for any help
Jerry
Joel
01-21-2004 06:22:15
 Re: Intake Valve interchangability on m9del B in reply to Jerry 41 B, 01-20-2004 19:33:50
Something is wrong with your old valves lenth. According the the JD parts book, the B2863R fits all models from ser. # 96,000 and up regardless of fuel type. I have 2 new B2863R valves here that I just bought from the JD dealer and they measure 6 7/8" O.A.L. My old valves that I am replacing were the same lenth. I don't know the spec's on the the earlier valves so if anyone has any let us know the measurement.
Joel
Ron
01-20-2004 21:23:09
Nope, something is wrong..!! generally, in the newer ones, the All-fuel valves are a different length ...
