JD R-92 riding lawn mower.
Joe McGinnis
10-04-2003 19:29:02
Need the wiring diagram for this mower. It would not start or even crank. Bought a new switch and cleaned all connections and put it back together. It still will not start. I can get the engine to turn if I by pass the solenoid. I think I made a mistake somewhere along the way. Any advice will be appreciated. Thanks and God Bless. Joe
Tramway Guy
10-04-2003 20:22:59
 Re: JD R-92 riding lawn mower. in reply to Joe McGinnis, 10-04-2003 19:29:02
Check your 'Neutral Gear' and 'Mower Deck Engaged' switches..the starter relay control current passes through both; if one is bad or unhooked, you will get the symptom you describe.
Follow the small wire back from the starter relay (mounted under the seat and you might be able to find the problem. A test light would be extremely helpful. Or a continuity tester of any sort to check each switch.
