JD M - I must be a glutton ! keep buying em and th
jody
10-09-2003 18:37:02
Pulled into the shed - nxt day pulled on the starter arm - nothing - battery is good as well as the starter - heard about a fuse - where the heck is it ??? could it be the ignition switch ? how can you ck the switch ? help !
scott beasley
05-15-2006 08:11:54
 slip clutch john deere in reply to
Mike M
05-15-2006 07:54:16
 Re: 35 B JD Hand Crank Problems in reply to Jak, 05-15-2006 06:46:45
Some are naturally hard starters. Sometimes if you do alot of trial and error you can help them out. Shuting the gas off and letting them run out sometimes helps restarting. Some need little throttle some need alot some need only half choke.
Then every so often you find one like I had last year and sold. It was an old B like yours. It had been sitting for years no one really knew the story. I checked the spark,had some,dumped gas in it gave it choke and some throttle and it soon fired up. Ran it around some but it was missing a tire on one side so couldn't really run it much. This thing would beltch out blue smoke and throw dropplets of oil out the stack. The engine had to be shot,but every time you wanted to start it there was no problem getting it going in just 1 or 2 seldom more turns. I wonder if it is still going to start as good after it is fixed ? Some just start and run no matter how bad they are !
alabamafrog
02-02-2009 15:43:56
 Re: Securing the seat in reply to 2cylinder, 01-28-2009 15:42:37
garytomaszewski said: (quoted from post at 19:43:24 01/28/09) Frog,
I'm going to assume that 80 MPH wind is from driving 55 into a
25 mph wind. LOL
I didn’t think about head winds, I guess I need to find some 110mph Velcro.
I usually try to keep it down near 70 when hauling 2 tractors on the interstate but occasionally might bump 80 when passing.
I might do both the tarp strap and put Velcro around the edges, I could keep the tarp strap in the battery boxes with the pipe covers and try to remember to put it on the seats each time I haul them.
This post was edited by alabamafrog at 15:45:28 02/02/09.
tom
10-09-2003 18:46:20
 Re: JD M - I must be a glutton ! keep buying em an in reply to jody, 10-09-2003 18:37:02
Jody,
The fuse in down in the lower part of the dash. If you stand by your cluth with the battery door open, the fuse should be just to the right of the battery inside the dash...it takes a 20amp fuse...if that is not your problem, post back and well help you...
tom
jody
10-09-2003 19:00:36
 Re: Re: JD M - I must be a glutton ! keep buying e in reply to tom, 10-09-2003 18:46:20
thank you ! I'll give it a try - any way to ck the ignition switch ?
