John Deere 1010 Crawler Tractor
John Stricklen
03-04-2004 18:01:42
Does any one know how to get parts #AT 18992 T, Gear Pump?
Adam
03-04-2004 20:27:08
 Re: John Deere 1010 Crawler Tractor in reply to John Stricklen, 03-04-2004 18:01:42
If this is the same pump as used in the 350's the gear set is AT18993 for $220, the housing AT27889 for $360 and the seal AT29365 for $14.25. I'm not sure if these would be the right parts but with the gear set here being one number different, I wouldn't be supprised if it was the right one. A dealership should be able to tell you if it would work. They can also search all dealers for NOS parts on their shelves. Ask the dealer to check the 350's for you. These were the numbers I got off their website. Hope this helps.
jdemaris
03-05-2004 09:36:42
 Re: Re: John Deere 1010 Crawler Tractor in reply to Adam, 03-04-2004 20:27:08
That's incredible. We used to change those gear-sets as a matter of routine whenever we had a reverser apart and they cost around $50. Of course, that was 20 years ago. I wish now I had saved the old parts we through out at the dealership.
jdemaris
03-04-2004 19:03:36
That's a pretty common part, just the gear-set for the pump in the reverser. Why don't you just buy the gear-set from a Deere dealer? As I recall, same thing is used in the 350s.
