Joe, Im not experienced on JD Tractors having more than just 2 cylinders, but have some info which may or may not be helpful. From your question, it sounded like you thought as RPM slows you need more advance???? A centrifugal advance increses timing advance as RPM increases. 1) Obviously, just cuz the picture you saw was of a distributor which happened to have a vacuum advance bulb, that doesnt mean a non vacuum advance equipped distributor now needs one due to the elec conversion. 2) Regardless if your or any distributor had either a vacuum or centrifugal or both advances, the physical mounting of a pickup coil versus points on the plate does not alter that. The faster elec switching might still call for slightly different advances. Its pickup coil (replaced points) still rotates as the base plate its mounted on rotates (due to vacuum or centrifugal forces) which, therefore, advances the time of firing at higher RPM and retards it at lower (includign starting). 3) If you have a working centrifugal advance plate, as RPM increses so does the timing advance, but as RPM's lower, the timing is more retarted closer to its start setting. You cant have much advance at cranking RPM's, cuz she will fire too soon (before piston at TDC) and kick back. However, as RPM increases, she can start the firign process earlier for more power. YOUR SPECIFIC QUESTIONS: Would a lack of advance make it start hard?? You dont want too much advance at starting to avoid kick back, still, if its wayyyyy too slow its harder to start. However, the advance mechanism doesnt slow timing down, it only advances it at higher RPM's. Your initial base start timing (nuttin to do with how much advance) set by distributor rotation in its mount, may need adjusting, cuz it might be tooooo slowwwww www, and if so it can affect starting. It may be more that shes initially base timed too slow affecting starting, not that she dont advance enough at RPM. Could a slow down on hills and hard startign be related???? Its posible, but your problem could also be carburetioin or engine problems versus spark or timing ASSUMING youre still developing a good hot blue spark and have good non fouling plugs. A weak ignition in general can cause BOTH hard starts and poor performance under loads (like maybe uphill), but you might also have a carb problem like too lean under load. SUMMARY I would first check where shes initially base timed at for starting (may be too slow) and then use of a timing light can show how she advances at RPM. In very general terms, an engine that is base start timed too slow cranks over easy, then seems to need to crank a bit and wind up before she starts. If shes base start timed too fast, she cranks hard and kicks back at the starter before she starts. Once shes start timed correct, a timing light will show how shes advancing. You might also want to check the fuel and carb to see if she needs richened up a bit under load. Hope this helps some?? Good luck n God Bless John T Nordhoff
