630 wiring diagram
Jimmy
03-16-2004 06:26:57
Could someone please tell me if there is a web site I can get one or maybe someone e-mail me one, Thanks..Jimmy
John T
03-16-2004 07:57:34
 Re: 630 wiring diagram in reply to Jimmy, 03-16-2004 06:26:57
Jimmy, I just sent you 2 separate e mails. One was 630 Lamp Wiring, the other was 630 Ignition and Generator Wiring, and it does show the "push start switch" as the good clooney man mentioned. Im unsure if he and I have the same diagrams, some of mine are fairly generic and I suspect he may have some that are more specific and accurate?? but we are glad to help as best we can, and I just send whatever I have, hopefully it will suffice.
John T
Ryan
03-16-2004 08:18:22
 Re: Re: 630 wiring diagram in reply to John T, 03-16-2004 07:57:34
Can you forward those wiring diagrams to me? I am working on my dad's 630 right now and I plan to update some of the wiring and install an alternator. I appreciate it.
Ryan
zahnryand@johndeere.com
John T
03-16-2004 08:32:54
 Re: Re: Re: 630 wiring diagram in reply to Ryan, 03-16-2004 08:18:22
You should have them both. Good Luck
Clooney
03-16-2004 07:33:59
Jimmy, most Deere wire diagrams for the 630 don't show the front & rear lighting wiring on the wire print & the ones that do are for the 620 so don't show the push button & solenoid starting.. If John's wire diagram doesn't show the light circuit or push button starting give me an E-Mail I will send you a different [later] wire print..
JDClooney@aol.com
John T
03-16-2004 06:29:51
Jimmy, e mail me with your return e mail address, and I will scan one of mine and send it to you.
John T jmn50@msn.com
