2010 hyds
John J. Otto
03-18-2004 09:12:41
i'm putting a loader on a '63 2010 this tractor only has a single remote can another outlet be added
chris
03-19-2004 13:00:16
 Re: 2010 hyds in reply to John J. Otto, 03-18-2004 09:12:41
Do you have the double or single hydraulics? To tell you can look at the left side of your rockshaft.(while facing the rear of the tractor) If you have two arms on one side and one on the other you have double, if only one arm on each side you have single. You should probably contact your local Deere dealer and ask a mechanic or the service manager.
chris
03-19-2004 12:59:08
Do you have the double or single hydraulics? To tell you can look at the left side of your rockshaft.(while facing the rear of the tractor) If you have two arms on one side and one on the other you have double, if only one arm on each side you have single. Either way probably the only way to do it would be to put in a flow divider and run another set of outlets. Even then you may not get the preformance out of it you would expect. Don't take my word for it though. You should probably contact your local Deere dealer and ask a mechanic or the service manager.
