730 clutch tightening up
John L.
03-18-2004 18:08:27
My 730 LP clutch works well but lately it seems to be getting a little harder to push over center. Would using the tractor very little cause this or should I expect something inside?
Clooney
03-18-2004 18:32:58
 Re: 730 clutch tightening up in reply to John L., 03-18-2004 18:08:27
John, sometimes when those 2-cylinder tractors sit for a while the clutch disks swell up a little form absorbing moisture into the disk material.. That can cause a tighter clutch feel..
~Try using the tractor for a while & see if the clutch feel returns to normal.. There really isn't much in that clutch to go wrong & make the clutch snap in harder unless you have rust forming on the adjuster bolts or operating parts.. Just use it a while & see if it gets better..
JDClooney@aol.com
John L.
03-19-2004 10:40:20
 Re: Re: 730 clutch tightening up in reply to Clooney , 03-18-2004 18:32:58
Clooney, Thanks for responding about my clutch, your comments always hit the spot.
