39 B Governor Bearings
John S.
03-19-2004 15:28:59
I need to put new governor bearings in my governor.I thought you could get them from deere.When I go onto JD parts web site the part number (JD7654R Bearing Complete) does not come up.I would like to know if there is a new part number so I can order the bearings.
Ralph - Wi
03-20-2004 09:14:36
 Re: 39 B Governor Bearings in reply to John S., 03-19-2004 15:28:59
I just bought 4 complete bearings for a 46 A.Two for the gov and two for the fan shaft. Listed without the R and about $30 ea.
Clooney
03-19-2004 17:34:15
John, those bearings used to be serviced in separate parts.. Try JD-7655R,, JD-7656R,, JD-7657R.. If that doesn't work have your Deere dealer check for subbed numbers for your number plus the numbers I furnished.. The "bearing complete" you are looking consist of the 3 numbers I furnished..
JDClooney@aol.com
Mike M
03-19-2004 16:22:36
Try dropping the R off the end of bearing numbers this should work.
