AR John Deere
Jeremy Brault
03-24-2004 06:55:50
I got An AR John Deere My question is that it will never start by hand, but when you pull it ten feet it is always running. I would like to be able to sart it by hand. So any help would be great.
Jeremy
David from Kansas
03-24-2004 07:01:49
 Re: AR John Deere in reply to Jeremy Brault, 03-24-2004 06:55:50
Jeremy,
I once had a farmall M with a mag which acted like your AR. I found out the impulse in the mag was worn out and I wasn't getting any spark unless the mag was turning at a higher RPM which was accomplished by pull starting. When I had the mag checked at a shop on a machine, there was no spark until the mag got up to high RPM and then it would throw a spark 3/4 of an inch. Check to see if you have spark while hand cranking and if you do then your problem lies somewhere else. Just a thought.
David
