governor settings for M
joe
03-26-2004 16:00:47
does anyone know the high idle speed setting for my M thanks alot Joe
Clooney
03-26-2004 17:20:53
 Re: governor settings for M in reply to joe, 03-26-2004 16:00:47
Joe, I show it's 1825 RPM [no load fast idle]..
JDClooney@aol.com
tom
03-27-2004 15:36:34
 Re: Re: governor settings for M in reply to Clooney , 03-26-2004 17:20:53
Clooney,
How do you calibrate the RPM's with anything on an old tractor without any needle on the instrument panel telling you how many RPM;s you are going?? Am I asking this right?
thanks,
tom
Clooney
03-28-2004 04:29:23
 Re: Re: Re: governor settings for M in reply to tom, 03-27-2004 15:36:34
Tom, that's a fair question...
Personally I use an electronic selectable input tac on the coil's distributor side but you can also use a hand held machine shaft speed tac on either the PTO or belt pulley [if it has one]...
____On the "M"____
PTO RPM [at 1825 engine RPM] = 609 RPM
Belt Pulley RPM [at 1825 engine RPM] = 1746 RPM
JDClooney@aol.com
tom
03-28-2004 05:54:17
 Re: Re: Re: Re: governor settings for M in reply to Clooney , 03-28-2004 04:29:23
Thanks Clooney...I knew there had to be a device that registered some kind of output to ascertain the RPM's.
If however, the compression was bad or some other engine debilitating issue [bad plugs, weak coil, etc] that impacted performance, would this give a false reading on the e-input tac? I guess the device will read whatever the performance is, but now what it should be. The reason I ask is that I would like to have my JD checked, but I believe i need new rings/valve job and perhaps more because of excessive blow-by.
thx, tom
Clooney
03-28-2004 06:45:09
 Re: Re: Re: Re: Re: governor settings for M in reply to tom, 03-28-2004 05:54:17
Tom, those selectable input tac's just read the number of times the points open per minute & compute that into Revolutions Per Minute. If the points are oxidized or otherwise won't always open & close reliably then the tac could have errors but under most conditions they work pretty good. If there is any doubt about ignition performance effecting the tac just use a hand held shaft speed tac on the PTO shaft..
JDClooney@aol.com
Joe
03-26-2004 19:24:15
Thanks for the reply, and info Joe
