JD G fan shaft
Jim G
01-24-2004 10:17:15
I'm trying to remove the drive gear on the fan shaft to replace a leaky O ring. I have the keeper off and trying to use a puller but it won't budge. any ideas? thanks
Clooney
01-24-2004 10:29:21
 Re: JD G fan shaft in reply to Jim G, 01-24-2004 10:17:15
Jim, just put the puller on it [a 3-jaw works best],, then apply a little quick heat to the gear [not on the teeth though] & it should pull right off.. Placing the shaft in an arbor press with a bearing splitter under the bearing also works good but usually requires placing the press up on wooden blocks..
JDClooney@aol.com
Jim G
01-24-2004 10:52:04
 Re: Re: JD G fan shaft in reply to Clooney , 01-24-2004 10:29:21
Thanks Clooney, i did use a 3 jaw puller but didn't try heat I'll do that. I did have a hard time keeping the jaws on , they keep slipping off. used a having tie wrap, helped but eventually came off
Clooney
01-24-2004 10:58:36
 Re: Re: Re: JD G fan shaft in reply to Jim G, 01-24-2004 10:52:04
Jim, try a large screw type hose clamp around the puller jaws [or hook 2 together if you need to make them bigger]....
