52 A transmission parts?????
Jerry
01-24-2004 12:50:56
Hi I have a 52 A with some transmission Problems and I was wondering if anyone could reccomend a supplier for replacement parts (salvage or new)
I need the following
a3803r- gear , countershaft Idler (sub for aa5430r) 35 and 22 teeth.
a4024r- Gear 4th & 6th speed sliding ( sub for aa5449r) 34 teeth
a2623r- Pinion, 5th & 6th speed sliding (sub for aa5505r) 15 teeth
And this last part I cannot tell for sure but the number appears to be aa156r or a4156r This is the short shaft right behind th first reduction gear. If any can confirm this number or reccomend a supllier for these parts it would be greatly appreaciated.
Thanks Jerry
37D
01-24-2004 13:45:21
 Re: 52 A transmission parts????? in reply to Jerry, 01-24-2004 12:50:56
There is a serial# break at #657392-657393 & my parts book shows different parts. The later tractor is shown as using part # AA5471R, subbed from #AA4850R. My understanding is that you need the shaft that the 1st reduction gear actually attaches to, & this the # my parts book shows for this part.
Rob
01-24-2004 13:36:51
Jerry- I have a 50 model A that I have for parts. The trans. is still in the tractor yet. I don't know if my 50 will mesh with your 52, but if it does I have parts for sale.
Leroy
01-24-2004 18:03:10
 Re: Re: 52 A transmission parts????? in reply to Rob, 01-24-2004 13:36:51
If I am not mistaken the 50 will have the double gearshift and the 52 I know is the single gearshift, so is the 51
Charles
01-25-2004 05:22:12
 Re: Re: Re: 52 A transmission parts????? in reply to Leroy, 01-24-2004 18:03:10
Leroy- What do you mean by a single and a double gear shift, just that it has a high and low?
Leroy
01-26-2004 18:27:20
 Re: Re: Re: Re: 52 A transmission parts????? in reply to Charles, 01-25-2004 05:22:12
The early tractors had a 2 speed transmission with a over dr for 4 speed, next series had 3 speed with over dr, later had a 6 speed with no overdrive
Jerry
01-24-2004 15:32:01
rob,
Would you email me with the serial number of your tractor and a phone number or your prefered method of contact.
Thanks jerry
**JEtzler1@aol.com**
Remove the ** ** to send me an email
Thanks.
Jerry
01-24-2004 15:31:00
rob,
Thanks jerry
Thanks.
