1966 JD 2510 Diesel Tractor
John Antonio (V
04-04-2004 08:31:55
Hello, I have a 1966 John Deere that is exhibiting the following:
(a) A combination of black (normal) and blue (maybe not so normal) smoke at start up and for approximately one minute or so after start up.
(b) "Missing" in the engine when a heavy load is being pulled.
Can someone give me any indication if I've got a problem??
Respectfully, John
Brokenwrench
04-04-2004 14:53:10
 Re: 1966 JD 2510 Diesel Tractor in reply to John Antonio (Virginia), 04-04-2004 08:31:55
Your black/blue smoke on start up,as long as it's alittle is normal. Your miss on a pull could be caused by dirty fuel filter,a restriction from the tank to the lift pump,a bad injector,injector pump timing,or clogged air filter. Did this just start or has it gotten progressively worse? Alittle more info might narrow it down.
04-09-2004 21:03:43
 Re: Re: 1966 JD 2510 Diesel Tractor in reply to Brokenwrench, 04-04-2004 14:53:10
Borkenwrench,
Thank you kindly for the help ..... I'll replace everything you mentioned one by one to narrow in on the problem..... the old girl is worth it !!!
Very Respectfully, John
