Flat Spoked Wheels
Dan Hanna
04-06-2004 12:55:42
I have obtained from Two Cylinder Club a Serial number research document for my tractor and on it for special equipment it has that my tractor came with flat spoked wheels. I would like to purchase a set of 38 inch 12 spline wheels for my 41 B. If anyone would have a set laying around please let me know and maybe we can work something out. Your help is appreciated concerning this matter.
ed b
04-06-2004 17:28:13
 Re: Flat Spoked Wheels in reply to Dan Hanna, 04-06-2004 12:55:42
as duane states 36 inch 12 spline i might have one laying around
Dan 41 B
04-07-2004 07:33:58
 Re: Re: Flat Spoked Wheels in reply to ed b, 04-06-2004 17:28:13
Ed B do you have one wheel and where are you located? I live in the Kansas City Area Please let me know what you have and what you would want for the wheel.
Thanks Dan 41 B
ed b
04-08-2004 16:21:29
 Re: Re: Re: Flat Spoked Wheels in reply to Dan 41 B, 04-07-2004 07:33:58
dan 41 b the # on the rim is jd 1259 r 12 spoke im located just outside of chicago ill i think i have the collar to
Dan 41 B
04-09-2004 07:36:14
 Re: Re: Re: Re: Flat Spoked Wheels in reply to ed b, 04-08-2004 16:21:29
What do you think that you want for the wheel? Can you send a picture of it to me? My email address is dhanna@amfam.com Thanks Dan
Duane Larson
04-06-2004 14:15:29
Dan,
The far majority of flat-spoke wheels I have seen are 36" (I don't recall any 38" flat-spoke wheels that are not cut-offs). The 38" tire only came into existence with development of the wide-base tire in 1938-39, and if Deere used 38" tires they normally used either pressed steel or cast wheels with removable rims.
F&H made some 38" round spoke wheels (with wide-base rims) but they are also rare.
Either the AB1820R 12-spoke, 12-spline wheel, (casting number JD1240R, if present, hub clamp B1189R) or the later version (heavier hub) of the AB1820R (casting number JD1259R), hub clamp B1961R, would be ok. The AA3814R 16-spoke wheel with a B2188R bolt-in hub was later (~1945). They all have 6.00S x 36" rims for 9.00x36" conventional tires (~corresponding to a 9.5x36" wide base tire available today).
Dan 41 B
04-07-2004 07:29:34
 Re: Re: Flat Spoked Wheels in reply to Duane Larson, 04-06-2004 14:15:29
Duane Thanks for the information. Do you know where a guy could get a set of the 36 inch wheels? Dan 41 B
