JD 730 clutch.
Joe
04-11-2004 14:38:39
Have a diesel 730 and had the clutch slip today on it. I haven't owned it long so I thought I would take it apart and check the facings. They all look relatively good, very smooth texture, no burned portions. I also checked all the steel maiting surfaces and they look pretty good, a little dull if anything. How this are the new clutch facings? Can the inner two plates be resurfaced or are they replace only. I may just stick it back together and try adjustment. I have only one other clutch experiance and that is on my 44' B. Any help or opinions would be appreciated. The IT manual says if the facings flex they should be replaced. Well only one is not mounted to a plate and ya I CAN bend it but not THAT easily. Thanks Joe
joe
04-11-2004 14:39:39
 Re: JD 730 clutch. in reply to Joe, 04-11-2004 14:38:39
I meant how thick, not THIS!? Are the new facings. Thanks Joe
