generator
Jim G
04-14-2004 13:51:59
i'm going to a tractor salvage where generators are off the tractors. how can i tell the differance between the 12v and a 6v. never really looked at one up close. thanks Jim G
John T
04-14-2004 14:21:09
 Re: generator in reply to Jim G, 04-14-2004 13:51:59
Jim, any info on the case is your best bet, but you may find some tractors with generators hanging on that still have an old battery stashed under the seat or elsewhere and see if they are 6 or 12 volt batterys, even though thats still no guarantee.
If you need any help getting one wired up and working, let us know. Best Wishes n God Bless
John T jmn50@msn.com
Jim G
04-14-2004 14:23:35
 Re: Re: generator in reply to John T, 04-14-2004 14:21:09
thanks John T i'll definately post if i run in trouble. Jim G
John T
04-14-2004 20:26:03
 Re: Re: Re: generator in reply to Jim G , 04-14-2004 14:23:35
Youre sure welcome Jim, A late G had a 12 volt generator most likely, and Ive had G's with 2 or 3 brush generators and they all had voltage regulators, so post back what you find and we will try n help you make her gennnnn nnn again.
John T
Clooney
04-14-2004 14:10:39
Jim, most Delco's are marked [stamped] on the case.. If you can tell us what tractor & appx. year you are looking for we can probably furnish you a few generator numbers that will work [again stamped on the case]....
JDClooney@aol.com
Jim G
04-14-2004 14:20:20
 Re: Re: generator in reply to Clooney , 04-14-2004 14:10:39
I'm working on a 52G. it has a car generator that my grandpa put on years ago. i'm trying to make it original. this guy i'm going to has several laying around. i'm not sure he knows so i'd thought i'd find out what to look for on the generator so i'd know thanks for response Clooney
Jim G
Clooney
04-14-2004 15:15:54
 Re: Re: Re: generator in reply to Jim G, 04-14-2004 14:20:20
Jim, you had to say late "G".. I probably have the least amount of electrical info on the late "G"..
~I do show it probably used the 1101777 12 volt generator, but a 1100955 should also work [they both take a voltage regulator instead of a cut-out relay]..
~You can make a lot of different Delco's work but the closer to original the easier & better..
JDClooney@aol.com
