2010loader
John J. Otto
04-26-2004 10:03:11
the rear axel brackets for a #36 loader does the locator notch go on the top or bottom also what is its capicity
John J. Otto
04-27-2004 08:07:55
 Re: 2010loader in reply to John J. Otto, 04-26-2004 10:03:11
the pin in the side frame is solid in the frame and it just lays in the axle bracket so i guess the real question is does the bracket keep the side frame from moving up or down thanks
firedog
04-26-2004 20:16:47
John,
The notch should be up to locate, then slide the pin thru the frame.
firedog
