loader stands
John J. Otto
05-04-2004 08:49:55
posted a want ad for loader stands for a # 36 loader on a '63 2010 if i can't find any does any one know how to build some
jbsmith
05-05-2004 20:42:51
 Re: loader stands in reply to John J. Otto, 05-04-2004 08:49:55
John-Ihad a 2010 with a 36loader.If your 2010 in narrow front,no problem.Mine had a wide front end.The problem is a 36 loader hangs under the rear axle if i recall correctly so the loader frame is lower than the front axle.I use to hang my loader from tree branches or barn beams with comalong winches just to get it off and I still had a heck of a time getting it high enough to clear the front axle.You could try getting four screw type implement jacks and welding the mounting brackets to the loader frame but thats not guaranteed to work and the more I think about it,if I still had the 2010 it would be easier and cheaper to build an A-frame hoist to hang the loader from.Sounds safer to plus it just doesnt seem right to weld stuff to your tractor.You would also have the A-frame to use for other things such as pulling motors etc.,if you make it wide enough you can back your truck under it to unload heavy objects.Well,I'm rambling now so good luck with your project.
John J. Otto
05-06-2004 09:27:59
 Re: Re: loader stands in reply to jbsmith, 05-05-2004 20:42:51
thanks i'll try that john otto
