H cylinder sleeves
Jeff
05-10-2004 14:13:20
Can an H be resleeved? It looks like it may not be possible with the little cuts for the plugs. Anyone know for sure?
Jeff
Clooney
05-10-2004 16:31:10
 Re: H cylinder sleeves in reply to Jeff, 05-10-2004 14:13:20
Jeff, yes an "H" can be re-sleeved.. It isn't cheap as you need to buy the sleeves, have the block machined for the sleeves, then press the sleeves in, then another machining process is needed to bore the sleeves out to proper size.. It will probably be just as cheap or even cheaper to bore the block out & install oversized pistons.. [at least get a price both ways]..
JDClooney@aol.com
