Johan, the same points (except possible differences in gaps due to rotor or cam or bushing problems), condensor and coil produces BOTH plugs sparks, so IF THE COIL IS PRODUCING IDENTICALLY GOOD SPARKS ON EACH MAG SNAP, but not out BOTH caps towers, again, Im still thinking the problem(s) are: a) A problem in the cap (internal tower terminals where rotor arm passes by). Look for cracks or carbon traces or crud or any subtle differences like different distances between where the rotor tip passes by the caps inner terminal/tower points. b) The brush or its spring or for free unrestricted inner/outer movement of the brush against the rotor arms pickup point. c) A problem in the rotor arm. d) There could be a rotor or cam or bushing problem. HOWEVER, IF BOTH mag snaps each produce near identical sparks out the coil wire alone, I dont think thats the problem at all. This assumes its ONLY ONE cap terminal that has a weak spark, regardless of wire or plug swapping AND BOTH PLUGS AND BOTH wires are good. Trying to answer your specific questions: (1)A weak spark strong enough to jump from coil but not first plug????? If the sparks real weak and there were losses in the wire and/or the plug was leaky or had a wider gap, I guess the answer would be yes. HOWEVER, if the coil wire alone is producing identically good blue (NOT faint thin wimpy yellow) on each mag snap, PLUS you have swapped plugs n wires and are SURE neither is the problem, Im back to a cap or brush problem. (2) Is there a build up in the coil for the second spark? YES theres an identical build up in the coil for BOTH sparks. However, its the same coil, points n condensor for BOTH, so if they are not equal, differences may be in the gap the points open to and maybe a problem in the rotor or cam or bushings. MAKE DARN SURE the coil wire alone produces near identical looking sparks on each mag snap,,,,, ,,,MAKE DARN SURE BOTH plugs n BOTH wires are good by new or swapping etc.,,,,, ,,,,MAKE DARN SURE the caps inner workings in the terminal pickup areas are the same and clean n free of carbon or crud or cracks and the distances from the rotor arm to the terminal points are near the same,,,,, ,,,MAKE DARN SURE the brush n spring and that area is clean and free. Sorry, without being there thtas about all I can think of fer now. Post back your findings and any more questions. I guess you know at idle with single barrell carbs, if you pul the left plug wire she will almost die, but if you pull the right it wont make near as much difference????? ????? ? John T
