john deere H
jeremy
05-26-2004 19:46:30
hi i have an H and the it has a humm to it i put new seals in the fan shaft and bearings and put the correct size shimms inbetween the govener case what else could it be would the hydrolic pump cause this if it were not shimmed correctly ?
Clooney
05-27-2004 03:34:27
 Re: john deere H in reply to jeremy, 05-26-2004 19:46:30
Jeremy, you didn't give the year of your "H".. The early [1939] are different than the later [40 & up]..
~First you are going to have to use a mechanics stethoscope, or long bar, or long piece of hose & listen to the different areas on your tractor to determine exactly where the noise is coming from..
~Your hydraulic pump could easily be the noise producer [that pump turns all the time].. It could also be excessively worm cam to governor gears [common on the early H’s],, or the L/H cam gear needs to be adjusted up tighter [later H’s],, or elliptical wear on the governor or cam gear [somewhat common problem].. Or even a loose L/H cam gear [somewhat common on the H’s]..
~It could also be your governor to fan shaft gears still making a noise.. Just adjusting [shimming] those gears won’t remove most howling noises until the gear set is run for quite a while to re-seat in to each other.. If you didn’t use a stone or fine grinder & remove the tooth end wear flash they might never quiet down..
~You can pull the fan shaft back out & run that tractor without the fan shaft in it & see if the noise goes away.. If that removes the noise remove the gear tooth end wear [sharp flashing] on both fan drive & driven gears with a stone, set then set the heels [backs] of the gears to be exactly even, & set the gear backlash [fan blade tip movement]to be about 3/8”-1/2”..
~If that pump is dry it must have oil in it or you can just remove the pump & install the later governor cover with the long snout on it [be sure to re-set the governor to fan gear backlash [fan blade tip movement]..
~If the noise is definitely coming from the fan gears & you are sure you set them up correctly & the tooth end flashing isn’t excessive you can try just operating the tractor for a few hours to see if the noise decreases after some break-in time.. It’s normal for those fan gears to howl a little if their adjustment is disturbed..
~If you can be more specific on exactly what’s causing the noise we can be much more helpful on how to eliminate the noise.
Any questions just post back or E-Mail…
JDClooney@aol.com
John T
05-26-2004 20:16:24
Jeremy, the last time I installed and meshed a set of fan and governor bevel gears, even though I set the mesh as perfect as I could tell, it also whined for a while, but once the gears seated in to each other, it ran quiet ever since. If they were meshed in too tight/deep it could whine also. Did you just re set the exisitng gears or did this involve a new set??? If a used set, were they both from the same tractor???
John T
