Wico Type C Mag. Coil
Jim Kinsella
05-27-2004 08:41:41
Can any of you mag folks tell me what wires in a coil are suppose to be used for what? Yep, I know, it sounds silly but here is what happened. I removed a coil from a working mag to do a better job of insulating the wires, and I installed new points and condenser in the mag. The wires were not original and looked pretty bad. It has 3 wires coming out of the windings. 2 were joined and then run to a ground screw, the other ran to the points. I broke one of the grounded wires off close to the windings and may not be able to solder it back.
I don't understand why there are 3 wires, should there be? How can I test the coil separately from the mag?
Thank You.
Jim
Louisville, Ky.
John T (Soldering)
05-27-2004 17:43:26
 Re: Wico Type C Mag. Coil in reply to Jim Kinsella, 05-27-2004 08:41:41
Hi again Jim, I just returned from dinner with the Marine son as hes headed out to 29 Palms for a while, so I thought I would add my thoughts on the soldering you might undertake if your coil passes the continuity checks Duane and I gave ya. On a coil having the twisted pair of external ground wires and tryign to solder a broken one together, heres how I would approach the problem.
1) The wire ends to be soldered gotta be clean all the way down to bare shiny metal and free, of course, of any insulation or oxidation or residue.
2) If theres sufficient length/slack, I suggest you loop and crimp the junction wires to add mechanical strength. If theres not enough wire exposed to do so, at least have the ends side by side where/if possible.
3) To help avoid any heat insulation damage, to the extent possible, heat sink (maybe use clamp on type tweezers) the wire where it goes to the inner coil area while still allowing the wire temp to reach good soldering capability.
4) Having the junction jigged up firm and heat sunk where possible, then tinning the wires then carefully soldering might well get you by.
5) A careful taping or otherwise securing the soldered junction to avoid stress is one last consideration.
Remember, the simple low voltage ohmmeter primary (ground to points, low ohms) and seconday (ground to side output button/terminal, high ohms) continuity checks Duane and I gave ya will tell you if a coils bad (open) or not, but even if it passes, it could still be faulty due to high voltage insulation break down failures.
Let us know how you make out, Good Luck
John T
Clooney
05-27-2004 11:29:16
Jim, Duane gave you some good coil testing data below.. I will just answer your other question..
You ask..
Quote: "I don't understand why there are 3 wires, should there be?" >>>
_Yes, Duane explained that below.. Those Wico coils have both a primary & secondary winding in them.. The primary winding runs from that ground wire set [one of the two wires going to that ring ], then through that single insulated wire exiting the coil & on to the points.. The secondary winding runs from that ground wire set to the high voltage button in the center of the coil [the one that the cap terminal touches].. When the internal magnetic rotor rotates inside the field laminations it induces a current flow in the primary winding.. Then, when the points open that current flow is quickly interrupted & the primary winding collapses.. That in turn induces a higher voltage in the secondary winding & that higher voltage [kilovolts] then passes through the spark rotor & on to the cap towers, then through the plug wires, then on to the spark plugs.. The return path from the plugs to the coil’s secondary side is through the engine block, to the governor, to the mag case, to that little ground ring & then through that second little ground wire into the coil.. That is a lot of words to say it should have those 3 wires.. Those 2 ground wires go to different places inside the coil. [one’s the primary ground & one’s the secondary ground..
JDClooney@aol.com
Duane Larson
05-27-2004 10:41:59
Jim,
On a Wico C coil (p/n X2766) the ground wires from one side of the primary (heavier wire) and one side of the secondary (smaller wire) are connected together and go under the screw which attaches the coil clamp on the lhs of the magneto. The other side of the primary goes to the points and the other side of the secondary goes to the HV button on the coil. The small secondary ground wire is usually wound around the heavier primary wire, then they are soldered together. I have had them break, and if you are careful you can normally solder an extension onto the broken wire. Be sure to clean and tin the wires first, as excessive soldering heat is not good for the insulation. Some coils do all the grounding internally and rely on grounding of the laminated center core.
Your primary should read 0.52 ohms (hard to read this low unless you have a good meter), and the secondary should read about 5000 ohms, plus or minus 1000 ohms.
John has covered other testing methods.
John T
05-27-2004 09:56:30
Jim, I have seen those coils over the years, depending on age and manufacturer, with different looking ground leads. Ive seen some with what appeared a small pair of bare wires which are, of course, the ground lead that's usually attached on or near a coil hold down. (On some, the ground lead is shorter than points wire). The wire to the points is, of course, single and insulated. The last one I bought from Robert Beaver had but 2 wires leading out of it (single external ground lead, maybe 2 were joined somewhere internally as a wire n shield???) and the wire to points and ground wire had 2 different size of terminals so they would ONLY FIT on the points screw and ground screw (one had a larger diameter ring terminal). Also, I had another one once that had similar size terminals, but the wire to the points had a heavier jacketed braided type insulation and the ground wire was still insulated (NOT a bare wire) but not with that heavier braided jacket like the points wire had. Ive also seen some where the ground terminal was a half round type versus the points terminal which was a full round ring terminal.
Sooooo ooo, I cant tell for sure sitting here what you have, but the ground and points leads should be somewwhat obvious based on if bare or twins (ground lead) versus the other ones insulated (and often longer) points wire.
Now to your question:
TESTING A COIL INDEPENDANT FROM THE MAG.
NOTE: Using a low voltage ohm meter can enable you to perform some preliminary checks which will show if a coil is DEFINITELY BAD, but it will NOT show if theres a high voltage insulation breakdown which will not be observeable using an ohmmeter. i.e. you may be able to tell if its BAD (not continuous/open) but just cuz it tests good using an ohmmeter, dont mean its positively a good coil. Under heat and high voltage an insulation failure can happen which a low voltage ohmmeter test will NOT find.
SIMPLE CONTINUITY AND RESISTANCE TESTS FOR PRIMARY AND SECONDARY WINDINGS
1) If you place an ohmmeter (x 1 scale) between the ground lead and the to points lead, thats the coils low voltage primary winding, which MUST BE CONTINUOUS (NOT an open) and very low ohms (under 3, Sorry I have no exact data/specs here).
2) If you place the meter between the coils side output button/terminal and ground (x 100 or x 1000 scale), thats the coils high voltage secondary winding, and it also MUST BE CONTINUOUS (NOT open), but of high ohms, maybe in the thousand(s).
3) For the coil to NOT BE DEFINITELY BAD, the primary and secondary MUST BOTH be continuous, the primary very low ohms and the secondary very high.
SIMPLE AS THAT
Notwithstandig it could still be a bad coil at high voltage per the above.
TESTIGN THE COIL INSTALLED IN THE MAG BUT INDEPENDANT OF ANY CAP OR ROTOR PROBLEMS.
If the coils installed but the cap removed and you place a wire or paper clip etc to the mags metal (ground) frame and the other end to within 1/8 inch away from the coils side output button/terminal, each time you rotate the mags rear coupler and make her snap, a good visible blue spark should jump that gap. If so, the coil n points n condensor is good. If she sparks there but NOT via out any installed cap terminals, theres a cap or rotor or terminal problem.
NOTE: On that Wico C, make sure the springy terminal on the inner cap makes good contact with the coils output button/terminal. if not, she wont transmit the spark to the outer cap n rotor.
Post back or e mail jmn50@msn.com any questions. Im pretty sure my friend Duane Larson has data n specs which may tell you more exact ohms readigns, but the general range I gave you will serve well enough to do the preliminary tests.
Good Luck n God Bless
John T
Jim Kinsella
05-28-2004 06:08:32
 Re: Re: Wico Type C Mag. Coil in reply to John T, 05-27-2004 09:56:30
WOW! What a bunch of great guys! I could not ask for a better response and explanation! I now understand how the coil works and how to test it. The science behind it is still majic, but I don't wish to understand that. My biggest challange will be to clean and soldier that little bit of ground wire barely sticking out of the winding. If I can't do that, it will be off to the supply house I'm afraid.
You good folks have definately helped get another John Deere running. Thanks!
Jim
John T
05-28-2004 07:17:19
 Re: Re: Re: Wico Type C Mag. Coil in reply to Jim Kinsella, 05-28-2004 06:08:32
Jim, youre most welcome, glad we were able to convey to you how to test it now (even though its not any complete HV test as I described for you below). Let us know how your soldering works out. If not, you can get those coils from many places including John Deere, heres just a few places you might consider.
Magneeders 417-358-7863 www.magneeders.com
McDonald Carb & Ignition Jefferson, GA 706-367-4179 www.mcdcarbign.bigstep.com
Roberts Carburetor Repair Spencer, Ia 712-262-5311 www.robertscarbrepair.com
I think I bought my last one (the one I described to you that just had 2 leads out that will work for your mag, one ground lead to attach to the mags frame/case ground, and the other to the points) from Robert Beaver.
John T
Jim Kinsella
05-28-2004 07:54:19
 Re: Re: Re: Re: Wico Type C Mag. Coil in reply to John T, 05-28-2004 07:17:19
John, thanks for the "leads" on new coils. I assume Robert Beaver is the same as Roberts carb repair.
I just soldiered the ground back in place! There was only 1/4" of frayed stranded wire coming out of the windings(down in a hole), so, testing is next to see if I melted everything together or not. The mag was working before I FIXED it....so the coil WAS good. We shal see!
Thanks again,
Jim
