620
Jim in Pa.
05-27-2004 11:06:36
There is a little wear between tha crankshaft splines and the clutch assembly, on my uncles 620. Is this a common problem? And what is the best way to fix this problem? Thanks, Jim in Pa
buickanddeere
05-27-2004 11:44:35
 Re: 620 in reply to Jim in Pa., 05-27-2004 11:06:36
Dengler makes clutch drivers with oversize splines to fit undersize cranks. They have pins,toggles etc that should be installed new incase wear is showing on the old ones. They even have rebuilt pulleys if the tabs are wallowed out oval/ovsize.
