630
Jim in PA
06-09-2004 14:46:00
will the three point hitch from a 2010, fit a 630???
Paul
06-09-2004 18:54:23
 Re: 630 in reply to Jim in PA, 06-09-2004 14:46:00
You could probably use the draft links, although you would need the elephant ears to go on the drawbar support or you could just put 1 1/8 inch bolt on pins in the holes in the drawbar support. The lift links would not have the proper type of connection to hook onto your rockshaft arms.
