JD 4640 with 158 loader?
Rueben
06-16-2004 13:21:40
Hi I have a JD 4640 and want to put a loader on it , I found a 158 will it fit on or do I need a 260 or a 280 loader?
Rick IA.
06-17-2004 06:55:45
 Re: JD 4640 with 158 loader? in reply to Rueben, 06-16-2004 13:21:40
Hi Rueban,
One of my friends has a 4630 with a 158 loader, I would think it would fit on your 4640.
Rick
LFN
06-18-2004 06:30:37
 Re: Re: JD 4640 with 158 loader? in reply to Rick IA., 06-17-2004 06:55:45
You are correct, a 158 will fit on a 4630 but not a 4640, as the frames are the same width but the radiator and sheet metal hood is wider than a 4630
LFN
06-17-2004 05:57:17
No, it's not wide enough to go around the 4640 front end
loader
06-16-2004 17:04:51
If my memory is correct, the loader for that series was numbered a 168 that fit on the 46 and 4840.
