40 single Touch-o-matic;,did now it doesn't!
Joe
06-18-2004 18:24:59
The t-o-m on my 40 won't move up or down,can't even take control past 1/2 down.It did work ok(was full of water and leaking oil around control shaft). I replaced seal around shaft and reassembled control rod ,etc. as it was. Now no movement,it is all the way up and small line from hyd. pump is getting hot(it is pumping oil, made a mess).Can't force rockshafts down.Any thoughts? Thanks a bunch guys! Joe
andy b.
06-18-2004 20:02:53
 Re: 40 single Touch-o-matic;,did now it doesn't! in reply to Joe, 06-18-2004 18:24:59
i had the T-O-M apart on my 40U about a month or two ago. i also replaced the seal on the control shaft. i didn't pay real close attention when i took it apart, and when i was putting it back together i realized you could put the control shaft and link back in 180 degrees out of line (upside down, if you wish). i guess i got lucky, because mine works. is it possible this is your problem? the bad thing is, if it is (or if you're not sure) you have to take the front cover back of the T-O-M housing to fix it.
another possibility is that you have something connected incorrectly from the load leveling linkage.
andy b.
