John Deere 4230 Hyd problems
Jeff
07-01-2004 15:26:45
I have a 73 4230, this is my primary tractor. The hydraulics work fine, but after 1/2 hour or so the hyd pump starts making noise. I have checked the fluid level, and changed hyd oil and filters. Also, the 3pt hitch drops very quickly once the tractor is turned off. Other than that it is 100% at 9242 hours.
Advice would be very much appreciated. Jeff
DON
07-02-2004 09:32:44
 Re: John Deere 4230 Hyd problems in reply to Jeff, 07-01-2004 15:26:45
SOUNDS LIKE THE THERMO RELIEF VALVE IN THE ROCKSHAFT VALVE HSNG IS LEAKING . WITH THE OIL HOT SEE IF YOU HEAR A HIGH PITCHED SQUEAL FROM THE VALVE HSNG. IMPROPERLY ADJUSTED CONTROL ROD WILL DO THIS ALSO. CHECK THE PUMP DRIVE BOLTS AND BUSHINGE FOR WEAR AND TIGHTNESS. DON
david val
07-02-2004 03:11:19
check the pump drive for ware for thr 'pump noise' (you have to remove the drive to check it properly). the drop of the hitch is a different problem and it's repairible on it's own.
david
