cleaned carb. but won't start-JD2020
Joe R.
07-04-2004 12:37:07
My 2020 was acting up, choking out while mowing, so I changed the fuelpump (Was weak) and cleaned out the carb.but now It runs for just a few seconds and that is with the choke pulled all the way out. I've had it apart four times now and cleaned out every jet I could find and still no good. What's wrong with it?
ags
07-05-2004 17:07:05
 Re: cleaned carb. but won't start-JD2020 in reply to Joe R., 07-04-2004 12:37:07
I had that same problem with my 9N. I cleaned the carb several times but it didn't help . Borrowed a friends air compressor and cleaned the carb a third time and blew it out with high pressure and that fixed the problem.
Joe R.
07-07-2004 20:39:45
 Re: Re: cleaned carb. but won't start-JD2020 in reply to ags, 07-05-2004 17:07:05
Well, I finally fixed the problem. It seems that the carb. load selenoid had a needle valve with a bad "o" ring that was bad and needed to be replaced. It was letting too much air into the bowl. Also, I took the airhose and cleaned it better than it was before. Thanks 'ags' for your input. Joe R.
