MT pulley lever swap......
Jim
07-26-2004 15:53:58
Is it possible to go though the gearshift cover to remove the pulley lever and install it on a different MT?
I want to install a pulley on my MT. What I can see inside the block off plate in the back, it has the "gear" that will accept a pulley shaft. But my MT does not have a pulley lever.
jd51mt
07-27-2004 13:20:33
 Re: MT pulley lever swap...... in reply to Jim, 07-26-2004 15:53:58
Jim
Thats how you do it. Put the transmission in neutral and remove the cover. The belt pulley for the "MT" will have a longer shaft then one made for the "M". I don't remember the length.
Jim
07-27-2004 13:32:36
 Re: Re: MT pulley lever swap...... in reply to jd51mt, 07-27-2004 13:20:33
jd51mt, Gonna take the lever out of a 50 MT and put it in a 51 MT, of course along with the pulley. Ahhhhh ..... ..greasy fingers again, I love it!! Thanks. Jim.
