wanted JD 4240 or 4440 no cab
jeremy roberts
07-29-2004 14:27:39
Wanted john deere 4220 or 4440 open station ruff tractor.. could have bad motor or be burnt... want to make puller out of it
G-MAN
07-29-2004 15:23:24
 Re: wanted JD 4240 or 4440 no cab in reply to jeremy roberts, 07-29-2004 14:27:39
Don't limit yourself to factory open-station tractors. Cutting the top off a burn Sound-Gard is pretty easy, and you'll end up with just about the same thing. A friend of mine did it with a burnt 4430 and it looked decent when he was done. And there's a 4055 running around these parts that had the same treatment, although I think it was originally a four-post ROPS. If you really wanted to get it light, you could cut off the outer and inner fenders and put bolt-on fenders on the final-drives, as long as you maintain some support for the side console or rig up a new one. That would probably get you even lighter than a factory open-station.
