Installing a head gasket
1951G
08-05-2004 13:50:30
I'm getting ready to install the head gasket on my 35 A. After looking at the gasket, I noticed it's the same on both sides with the exception of the rings around the cylinders. On one side there is a seam and the other is smooth. Which side faces the head? I'm assuming the nuts on the head studs have only a lead washer behind them versus a lead washer with a regular cut washer. Also, I'm not soaking the head in oil but using copper coat on both sides. Is this the way to go? Thanks in advance.
1951G
08-06-2004 08:05:12
 Re: Installing a head gasket in reply to 1951G, 08-05-2004 13:50:30
Thanks again for the help.
Duane Larson
08-05-2004 21:22:39
1951G,
The smooth side of the head gasket goes toward the block, as noted earlier. The nuts only have the lead washers between them and the head. I use 2-3 light coats of copper coat on the head and block, waiting a minute or so between coats, then assemblying and torquing - with retorquing after the engine warms up. Others have noted in previous posts that applying the copper coat to the gasket causes a coating on the gasket to release (or so it appears).
Butch ( PA )
08-06-2004 01:21:06
 Re: Installing a head gasket in reply to Duane Larson, 08-05-2004 21:22:39
Duane, what is copper coat? I'm just about ready to put my head gasket on my 49' "A"
Duane Larson
08-06-2004 06:13:42
 Re: Installing a head gasket in reply to Butch ( PA ), 08-06-2004 01:21:06
Butch,
As I recall (I'm not in the shop now) both Permatex and K&W (and probably others) make a spray-on gasket sealer which contains copper to aid in heat conduction. Most any auto parts store will have some. What also works well is just regular aluminum paint - a couple of light coats will help seal the gasket, and aluminum is a good heat conductor. Assemble before the paint is dry.
Jon C -florida
08-05-2004 18:06:25
1951G-
I placed the rolled lip toward the cylinder and the flat toward the head, but I'm not sure it matters.
I didn't soak the head gasket in oil but did put just a little "shallac" type coating on the gasket...and I'm not sure that matters either.
Just the lead washers goes under the nuts with no other washers.
So, I think you are on the right track, and should not have any trouble.
You should re-torque after it has been run a little.
1951G
08-05-2004 13:52:16
Sorry, I meant to say "not soaking the head gasket in oil instead of head before installing".
