Front wheels on 1935 A
1951G
08-11-2004 08:52:43
I'm trying to install my front wheels on the 35 A. The problem is the threads are worn down almost flat on the spindles. I'm thinking of using a castlenut that has a locking bolt going through it in addition to the cotter pin versus the regular castlenut without this clamping bolt. Will this work or is there something else I could do to ensure the castle nut stays on spindle?
Clooney
08-11-2004 09:19:30
 Re: Front wheels on 1935 A in reply to 1951G, 08-11-2004 08:52:43
1951G, it depends on how bad the spindle threads are..
I have done want you want to do many times & usually first run a die over the existing threads to straighten them out & stand them up a little..
As long as the pinch nut tightens down enough to hold tight & not spin free when the pinch bolt is tightened it will hold & work good for you..
JDClooney@aol.com
1951g
08-11-2004 10:38:21
 Re: Front wheels on 1935 A in reply to Clooney, 08-11-2004 09:19:30
Thanks Clooney. I'll try that and see.
