64 4010D Hyd. problem
Jim in AK
02-02-2004 15:35:45
The remote hyd. only works in one derection. If I switch the hoses it workes in the other derection but still only one way. Any help please!
Jim in AK
Uncle
02-03-2004 05:41:23
 Re: 64 4010D Hyd. problem in reply to Jim in AK, 02-02-2004 15:35:45
Jim, Why don't you take the quick coupler ends (at the hose ends) off to see if some crud is blocking the ball and seat...also make sure the hose is plugged in good and the little lever is swung all the way to lock it once it's pluuged into the tractor....once while drilling wheat , the lever, or lock...whatever you call it, popped partway back and the drill did not fully go down , had some weird looking rows.... could be moisture freezing in there too, at the narrow orfice( ball and seat) I wish you luck....Keep warm! Uncle
ron
02-02-2004 17:42:57
probably will find problem in the remote valve itself. had john deere rebuild mine a week ago.
Jim in AK
02-02-2004 23:05:04
 Re: Re: 64 4010D Hyd. problem in reply to ron, 02-02-2004 17:42:57
Are you talking about the brake away valve in the back or the control valve in the dash?
Jim B in AK
Ray
02-02-2004 17:18:01
Change to another hyd cylinder see if it disapears ill bet its a bad male hyd coupler
old
02-02-2004 16:24:50
Sounds like its set for single acting cylinders, there a way to set it for double but I don't know how its done. If you have a manaul or a dealer close one of them could tell you. You could also maybe go to johndeere.com and ask
Jim in AK
02-02-2004 16:53:21
 Re: Re: 64 4010D Hyd. problem in reply to old, 02-02-2004 16:24:50
It operates a dozer blade and has been working well untel yesterday. Started getting slower and slower so I parked it. Today it would only work in one derection. I got a book. Couldn't find any help in the trouble shooting index. JD rebuilt the quick disconect valve about 30 hrs ago!
Jim in Ak
old
02-02-2004 17:05:20
 Re: Re: Re: 64 4010D Hyd. problem in reply to Jim in AK, 02-02-2004 16:53:21
Could you have some water in the system that frooze up in one of the lines or valve?? Not sure of where your at if AK means Arkansas that probaly isn't your problem, unless your in the north part
Jim in AK
02-02-2004 23:01:32
 Re: Re: Re: Re: 64 4010D Hyd. problem in reply to old, 02-02-2004 17:05:20
AK is ALASKA no it is not ice it was in a warm garage all night. I live 62 miles north of Anchorage. AR= Arkansas. I think the problem is in the remote brake away valve.
Thanks to all.
Jim in AK
