36 a crank dimensions
Jim Benson
08-17-2004 07:02:05
I need to get a sleeve on the area of the crank where the throwout bearing rides. What is the dimension (diameter) for that area?
Clooney
08-17-2004 07:19:35
 Re: 36 a crank dimensions in reply to Jim Benson, 08-17-2004 07:02:05
Jim, that [Deere] "A" doesn"t use a throw-out bearing.. It uses a sliding sleeve on the clutch pulley hub.. Are you referring to the crankshaft area were the outer clutch pulley bearing inner race sits, or the where the pulley inner brass bushing rides, or to the place on the pulley hub where the operating sleeve slides?
JDClooney@aol.com
