 45A, the governor spring is correct when you pull the hand lever all the way to the rear,, then hold the governor arm in place,, then move the hand throttle to wide open.. If the spring & arm are on correctly the spring will bend when the hand throttle is advanced… Then when you let go of the governor top lever it should snap the carb to wide open [all done with the engine NOT running].. You ask .. Quote: “I’m not exactly clear as to how it should work. It appears to me, that centrifugal force of the flyweights would cause them to move away (toward right side)from the control arm, and if the control arm (fork) isn"t in contact with the weight assembly (mine isn"t, at the moment) the governor would have a hard time controlling speed. Am I missing something here?”….. --I’m not exactly sure what you are saying here so see picture…The governor’s job is to TRY & hold the carb’s throttle plate closed as much as possible.. The spring’s job is to try & open the carb’s throttle plate as far as possible.. When the governor weight pressure balances the spring pressure the throttle stays steady,, as the engine slows down the governor weights lose some of their centrifugal force so loose some push & the spring wins & opens the throttle more… When the engine revs higher the governor weights gain some centrifugal force so gain some push & the governor wins & closes the throttle more.. It’s a simple push & shove match between the governor weights trying to close the throttle & that big flat spring trying to open the throttle.. In a nut shell,, simple as that! Quote: “how is the W.O.T. set? Is there a special tool for this, or is engine speed limited "by design" of throttle, governor (if working)?”…. ---The “W.O.T.” is set by a limit bolt at the hand throttle lever area.. It just limits the distance the hand lever can deflect the governor arm spring.. To tell what the “W.O.T” engine RPM is you need a hand held shaft speed tac to place on the center of the either the crankshaft or the PTO shaft then count the revolutions for one minute.. Any more questions just post back.. JDClooney@aol.com
