JD 720 std - same 3 point as a rowcrop?
Joey
08-31-2004 09:13:47
WOdnering if all 720 3 points are the same...in other words, will the lift arms off a rowcrop 720 work on a standard or is there a difference in the length, height, etc.
Thanks for your help
Tyler-MO
08-31-2004 09:26:45
 Re: JD 720 std - same 3 point as a rowcrop? in reply to Joey, 08-31-2004 09:13:47
They will bolt on yes....but the top part of the arm (where the clutivator rods would fasten onto the arms) You may have interference with the platform if you use row crop rockshaft arms. If you don"t care I suppose that you could cut off the part of the arms that will interfere. Some might balk at that but if it will work it could be much cheaper than finding original standard rockshaft arms. Good Day
Tyler
