larger pistons
4020plus
09-08-2004 11:55:45
I have heard of guys putting 466 cu. pistons from newer john deeres in 4020s for more horse power. this tractor is for pulling what do they do to make them work?
G-MAN
09-08-2004 13:57:12
 Re: larger pistons in reply to 4020plus, 09-08-2004 11:55:45
Buickanddeere is right. Improving the airflow is more important than adding those cubes, at least unless you want to really go whole-hog. Even with an M&W turbo, you can still overfuel a 4020 with the stock fuel system. I overhauled a 4230 recently, and noticed that the head on that 404 used the same one-into-two port design that made the 55-series and newer 6076 (466) heads so much better than the earlier ones. I think that a 4455 head would fit on a 4020 block, but you'd have to do some measuring to make sure the edges of the valves cleared the sides of the bores. They might not even come close to hitting, but I'd make sure first. But if I were going to do some tweaking on a 4020, I'd definitely look into a 4230 head and doing some porting and polishing. It will obviously fit that bore size, and would probably be MUCH cheaper than a 6076 head. The other thing to consider would be simply swapping in a complete 6466T engine. There would be some hood modifications to do to clear the turbo, probably do some other tweaking and the like and you'd have to be a little careful putting 150+ horsepower in front of a 90-horse trans/rear-end and behind a 90-horse radiator, but other than that, it would be a bolt-in operation. It all comes down to how much you want to spend and what you have access to. I myself would LOVE to have a 4320 with a 466 in it.
buickanddeere
09-08-2004 12:22:21
More airflow through a better head/port/manifold will be required to realy take advantage of the 404 engine let alone a 466. 50 and later series heads are supposed to be a bolt on with much betetr flow. G-Man has the mixing and matching figured out.
