old 7520 4x4 tractor pull a
jfdse
09-09-2004 12:11:19
what size disc chisel should this tractor handle, also plow, and disc. thinking of getting one.
4240puller
09-11-2004 12:28:49
 Re: old 7520 4x4 tractor pull a in reply to jfdse, 09-09-2004 12:11:19
It will easily pull an 11 shank chisel plow because we were using our 6030 on it and it handled it just fine and it only weighed 14000 lbs. with duals.
robertq
09-09-2004 19:25:16
pulls 11 shank soilsaver good.30 ft plus cultivator .
John J
09-09-2004 14:30:00
We had one with 18.4 x 34 rubber (w/ hub duals) that could pull our 26’ Case D.O.T. harrow 5-6 mph in heavy clay soil which was a pretty good feat considering the harrow weighed in the 20-21,000 lb range! We also pulled a 16 ft KMC integral chisel plow with it and although we never hooked them up, I’m sure it would have pulled our 9 shank Barrentine subsoiler because our 6030s could pull it. We mostly used that 7520 to pull a 22’ Forrest City Do-All and 22’ Barrentine Spike Toothed Harrow in tandem to incorporate pre-
emergence herbicides for soybeans. Hope this helps.
Leland
09-09-2004 13:23:53
It should handle a 12-14 ft chisel I've seen 8 bottom plows behind them and 30 ft disks being pulled.
